shp2tile question
Don Deskins
dldeskins at GMAIL.COM
Mon Apr 11 16:38:19 EDT 2005
Bart and Steve,
My shapefiles are showing up now... thanks!
Now I have a time problem... It seems to take more time to generate
the image than it did before. I am checking for errors now.
Thanks again.
Don
On Apr 11, 2005 3:28 PM, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
> Hi Don,
> check the dbf of your generated tileindex (the LOCATION field). I usually
> use absolute paths in there. Are there absolute or relative paths to the
> files in there?
> Also use TYPE POLYGON. Are you zoomed in enough to have your layer showing
> up, since you are using a MAXSCALE setting?
> Best regards,
> Bart
> On Mon, 11 Apr 2005 15:24:45 -0400, Don Deskins <dldeskins at gmail.com>
> wrote:
> > Bart (and Steve),
> > Thanks.
> > I have my files created and tried to reference this index in my map file:
> > # parcels
> > LAYER
> > NAME 'tileindex'
> > TYPE TILEINDEX
> > DATA '/path/to/tileindex'
> > MAXSCALE 40000
> > END
> > LAYER
> > NAME 'SCAP_Cert2004_ParcelsUTM16M'
> > STATUS ON
> > TYPE POLYGON
> > TILEINDEX '/path/to/tileindex'
> > #TILEITEM 'LOCATION'
> > MAXSCALE 40000
> > END
> > I get no error but my shapes are not showing up... do you see a
> > problem with the above map?
> > Don
> > On Apr 11, 2005 2:58 PM, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
> >> Hi,
> >> It is tile4ms, not tile2ms, probably a typo by Steve.
> >> It is a Mapserver utility to make a tileindex. Alternatively, you can
> >> also
> >> use ogrtindex for vector layers and gdaltindex for raster layers.
> >> Best regards,
> >> Bart
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Don Deskins
