problem with tiled layer
Hunter, David - St. Louis Park, MN
David.Hunter at FNF.COM
Tue Aug 2 18:01:01 EDT 2005
I upgraded to 4.6, and I get an application error, mapserver is
attempting to write to address 0x00000010. I traced it down to using
highway shield symbols. When I remove the major roads label layers, the
error goes away. If I change the path to the symbol .PNGs, I get a
mapserver-generated error message.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Frank Warmerdam
Sent: Tuesday, August 02, 2005 4:11 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] problem with tiled layer
On 8/2/05, Hunter, David - St. Louis Park, MN <David.Hunter at fnf.com>
wrote:
> Should I try and upgrade to 4.6? What would be involved, merely
copying
> the contents of the bin directory to my cgi-bin?
David,
Well, that depends on your circumstances. Where you get your
binaries, etc. Generally speaking the .map file and other application
components should be pretty compatible between 4.4 and 4.6 so the
main issue is replacing your binaries and support libraries with a newer
version.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
