transparent hatch
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Aug 4 18:46:46 EDT 2005
On 8/4/05, Frank Warmerdam <fwarmerdam at gmail.com> wrote:
> On 8/4/05, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> > Since Mapserver 4.4, when I want to output jpegs, if I want a simple
> > vector hatch to be transparent (for underlying layer to show thru) I
> > have to set IMAGEMODE PC256:
> > OUTPUTFORMAT
> > NAME jpeg
> > DRIVER "GD/JPEG"
> > MIMETYPE "image/jpeg"
> > IMAGEMODE PC256
> > EXTENSION "jpg"
> > END
> > If I use IMAGEMODE RGB, the space between the vector lines is opaque white.
> > My symbol definition:
> > Symbol
> > NAME 'Diag_NE_SW'
> > TYPE VECTOR
> > POINTS
> > 0 1
> > 1 0
> > END
> > END
> > And my class definition:
> > CLASS
> > NAME "FEMA 500 Year Flood Zone SHX"
> > EXPRESSION 'SHX'
> > STYLE
> > COLOR 112 186 248
> > OUTLINECOLOR 0 0 255
> > SYMBOL 'Diag_NE_SW'
> > SIZE 20
> > END
> > END
> > Am I overlooking anything? I would prefer to use IMAGEMODE RGB.
> Rich,
> Try adding a "TRANSPARENT ALPHA" line in your layer definition.
> Amoung other things this enables the alpha blending needed for
> raster symbols with transparency.
> I'm not really satisfied with this requirement, though it is organized
> this way partly to avoid extra work in the common case where there
> is no transparency.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Thank you Frank, you always have the answer!
For the record; it is "TRANSPARENCY alpha" (not TRANSPARENT).
Best regards,
Richard Greenwood
www.greenwoodmap.com
