Mapserver Setup Problems, Any Suggestions?
Trevor Penney
Trevor.Penney at NOVAGEOMATICS.COM
Tue Aug 9 22:53:37 EDT 2005
The problem with the GCC compiler has to do with the server, there is
not quite
eneough resources to get GCC installed.
Trevor
Quoting blaise <bpicinbono at WORLDONLINE.FR>:
> lundi 8 Août 2005 18:46, Trevor Penney :
>> Hi All,
>> I am having some problems with setting up mapserver, any suggestions would
>> be greatly appreciated.
>> Basically I want to install mapserver. I have root access and Fedora Core
>> 2. However, I can't use gcc to compile the mapserver from source, and
>> unfortunately FGS isn't an option because I can't run more than 1 http.d,
>> due for server reasons. Any suggestions on a work around, such as an RPM or
>> something?
>> If you know of anyone else I could contact that would be great.
>> Thanks for any input!
>> Trevor Penney
> Why can't you use the gcc compiler ?
> Blaise
