limit in PostgreSQL
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Aug 11 22:56:56 EDT 2005
Jason FU wrote:
> In Oracle, we have rowid for limiting the number of selected rows/records.
> In PostgreSQL, we have limit and offset. But how do we use limit in the
> MapServer. For Oracle spatial, we simply add rowid in the FILTER statement.
> What do we do in PostGIS connection?
DATA "the_geom from (SELECT gid, the_geom, ... FROM mytable LIMIT 2000)
as foo using srid=4326 using unique gid"
so basically you can put any SQL query as a sub-select as long as you
return at least the_geom and gid or oid, other fields can be used for
class expressions.
-Steve W
http://imaptools.com/
