limit in PostgreSQL
Jean-Denis Giguere
jdenisgiguere at FASTMAIL.FM
Fri Aug 12 00:00:47 EDT 2005
Stephen Woodbridge wrote:
> Jason FU wrote:
>> In Oracle, we have rowid for limiting the number of selected
>> rows/records.
>> In PostgreSQL, we have limit and offset. But how do we use limit in the
>> MapServer. For Oracle spatial, we simply add rowid in the FILTER
>> statement.
>> What do we do in PostGIS connection?
> DATA "the_geom from (SELECT gid, the_geom, ... FROM mytable LIMIT 2000)
> as foo using srid=4326 using unique gid"
> so basically you can put any SQL query as a sub-select as long as you
> return at least the_geom and gid or oid, other fields can be used for
> class expressions.
> -Steve W
> http://imaptools.com/
Is there a trick to use the spatial index automatically generated by MS
inside the sub-select query ? This could be useful when you want to use
complex request on a small part of a large database.
Regards,
Jean-Denis
