raster to pdf
Andrew Huang ahuang at GEOANALYTIC.COM
Tue Aug 16 11:25:49 EDT 2005
I'm trying to get mapserver to output a pdf file from a tiff image.
I can't seem to find much documentation about creating pdf files with mapserver so I thought I'd post something in here.
I'm able to create a pdf, but the file seems to only have 256 colors.
Below is a copy of the map file I use. Am I doing something wrong?
MAP
    NAME test
    STATUS ON
    OUTPUTFORMAT
     NAME pdf
     MIMETYPE "application/x-pdf"
     DRIVER pdf
     IMAGEMODE RGB
     EXTENSION "pdf"
    END
    SIZE 10800 10800
    EXTENT 679793.750000 5485393.75 717518.75 5515106.250000
    UNITS METERS
    PROJECTION "proj=utm" "ellps=clrk66" "zone=11" "datum=NAD27" END
  LAYER
   NAME "82G09"
   TYPE RASTER
   STATUS ON
   DATA "082G09FN.tif"
  END
END
Thanks,
Andrew
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050816/31dba18c/attachment.html
