ASP.NET and mapscript - unable to load DLL
Abe Gillespie abe.gillespie at GMAIL.COM
Fri Aug 19 11:38:13 EDT 2005
Placing the depended-on DLLs into the bin dir will do nothing.  I
assume you're on a windows box.  Therefore the easiest way to take
care of this is by placing all the DLLs (except for map_script) into
<windows>\system32 where <windows> is the system windows directory
(c:\winnt, c:\windows, etc.).
With that said, you're entering a world of pain by using C# map_script
in ASP.NET.  Much of the map_script DLL is thread unsafe, that
combined with ASP.NET's supremely weird threading model (e.g. virtual
threads), you're going to encounter a plethora of problems.  This is
why you almost never see MapServer + ASP.NET discussion threads.
To get more info, search the archives.  You should find ten or so
messages about this topic.
-Abe
On 8/18/05, Mike Boos <mboos at augsignals.com> wrote:
> Hello
> I'm trying to run Mapscript using the SWIG C# bindings on an ASP.NET
> server. I compiled the 4.6.0 version of MapServer and have placed what I
> believe to be the appropriate dependencies (mapscript_csharp.dll,
> mapscript.dll, libmap.dll, bgd.dll, gdal12.dll, pdflib.dll) in the bin
> directory on my server. It is appears to be finding
> mapscript_csharp.dll, but is having trouble finding mapscript.dll or one
> of its dependencies. I am seeing the following error message:
>   Server Error in '/' Application.
>     /Unable to load DLL (mapscript)./
> * Description: *An unhandled exception occurred during the execution of
> the current web request. Please review the stack trace for more
> information about the error and where it originated in the code.
> * Exception Details: *System.DllNotFoundException: Unable to load DLL
> (mapscript).
> Am I missing a dependency? Or do I need to set some configuration option
> or place the files elsewhere?
> Thanks!
> Mike Boos
