ASP.NET and mapscript - unable to load DLL
Mike Boos mboos at AUGSIGNALS.COM
Fri Aug 19 11:53:54 EDT 2005
I tried moving the dlls to the system32 directory, but that doesn't have
any effect (am I missing any other dependencies?)
Unfortunately, I'm kind of stuck with ASP.NET, as that's what the rest
of the site relies upon. I'm trying to improve the present setup which
involves sending a request to a C++ CGI program which writes a map file
to the hard disk and forwards the request to mapserv.exe. If you'd ask
me, that's a bit of a kluge, and without Mapscript, all I could do to
improve on that would be to take out the C++ program and have the map
file generated from within the ASP.NET program itself. Can you think of
a better way to accomplish the same task?
Mike
Abe Gillespie wrote:
>Placing the depended-on DLLs into the bin dir will do nothing.  I
>assume you're on a windows box.  Therefore the easiest way to take
>care of this is by placing all the DLLs (except for map_script) into
><windows>\system32 where <windows> is the system windows directory
>(c:\winnt, c:\windows, etc.).
>With that said, you're entering a world of pain by using C# map_script
>in ASP.NET.  Much of the map_script DLL is thread unsafe, that
>combined with ASP.NET's supremely weird threading model (e.g. virtual
>threads), you're going to encounter a plethora of problems.  This is
>why you almost never see MapServer + ASP.NET discussion threads.
>To get more info, search the archives.  You should find ten or so
>messages about this topic.
>-Abe
>On 8/18/05, Mike Boos <mboos at augsignals.com> wrote:
>>Hello
>>I'm trying to run Mapscript using the SWIG C# bindings on an ASP.NET
>>server. I compiled the 4.6.0 version of MapServer and have placed what I
>>believe to be the appropriate dependencies (mapscript_csharp.dll,
>>mapscript.dll, libmap.dll, bgd.dll, gdal12.dll, pdflib.dll) in the bin
>>directory on my server. It is appears to be finding
>>mapscript_csharp.dll, but is having trouble finding mapscript.dll or one
>>of its dependencies. I am seeing the following error message:
>>  Server Error in '/' Application.
>>    /Unable to load DLL (mapscript)./
>>* Description: *An unhandled exception occurred during the execution of
>>the current web request. Please review the stack trace for more
>>information about the error and where it originated in the code.
>>* Exception Details: *System.DllNotFoundException: Unable to load DLL
>>(mapscript).
>>Am I missing a dependency? Or do I need to set some configuration option
>>or place the files elsewhere?
>>Thanks!
>>Mike Boos
