ASP.NET and mapscript - unable to load DLL
Mike Boos
mboos at AUGSIGNALS.COM
Fri Aug 19 16:58:00 EDT 2005
Thank you for that advice! I ran filemon and discovered that it was
trying (unsuccessfully) to find libcurl.dll - which somehow didn't show
up in my dependency tracking tool. It's now in my system path.
I'm now running into new trouble. When I try to create a mapObj with
"mapObj m_obj = new mapObj(mapfile);" I get the following error:
/Object reference not set to an instance of an object./
* Description: *An unhandled exception occurred during the execution of
the current web request. Please review the stack trace for more
information about the error and where it originated in the code.
* Exception Details: *System.NullReferenceException: Object reference
Any suggestions?
Mike
Tamas Szekeres wrote:
>Have you tried SysInternals's filemon or a similar program to monitor the
>expected location of theese files?
>On Fri, 19 Aug 2005 13:23:38 -0400, Mike Boos <mboos at AUGSIGNALS.COM> wrote:
>>mapscript_csharp.dll is present in the bin directory. All the others are
>>in system32. gdal12.dll is in both as I'm somehow invoking a function
>>from it from elsewhere and not having the slightest bit of trouble with
>>that part (I'm using a direct DllImport attribute). So maybe I will have
>>to try one of the alternatives. Oh well.
>>Mike
>>Abe Gillespie wrote:
>>>Did you move mapscript.dll to system32 as well? The only DLL that
>>>should be in your bin dir is mapscript_csharp.dll.
>>>Suggestions:
>>>1. Write the mapfile by hand with the file streaming objects?
>>>2. Wrap the MapServer CGI executable with ASP.NET (I think someone
>>>did just this some time ago).
>>>3. If this is all you're doing, you *might* be able to get away with
>>>it in ASP.NET. See if there's a way to protect a section of ASP.NET
>>>code with a semaphore or similar construct. Is there something that
>>>protects in the virtual thread environment?
>>>-Abe
>>>On 8/19/05, Mike Boos <mboos at augsignals.com> wrote:
>>>>I tried moving the dlls to the system32 directory, but that doesn't have
>>>>any effect (am I missing any other dependencies?)
>>>>Unfortunately, I'm kind of stuck with ASP.NET, as that's what the rest
>>>>of the site relies upon. I'm trying to improve the present setup which
>>>>involves sending a request to a C++ CGI program which writes a map file
>>>>to the hard disk and forwards the request to mapserv.exe. If you'd ask
>>>>me, that's a bit of a kluge, and without Mapscript, all I could do to
>>>>improve on that would be to take out the C++ program and have the map
>>>>file generated from within the ASP.NET program itself. Can you think of
>>>>a better way to accomplish the same task?
>>>>Mike
>>>>>Placing the depended-on DLLs into the bin dir will do nothing. I
>>>>>assume you're on a windows box. Therefore the easiest way to take
>>>>>care of this is by placing all the DLLs (except for map_script) into
>>>>><windows>\system32 where <windows> is the system windows directory
>>>>>(c:\winnt, c:\windows, etc.).
>>>>>With that said, you're entering a world of pain by using C# map_script
>>>>>in ASP.NET. Much of the map_script DLL is thread unsafe, that
>>>>>combined with ASP.NET's supremely weird threading model (e.g. virtual
>>>>>threads), you're going to encounter a plethora of problems. This is
>>>>>why you almost never see MapServer + ASP.NET discussion threads.
>>>>>To get more info, search the archives. You should find ten or so
>>>>>messages about this topic.
>>>>>-Abe
>>>>>On 8/18/05, Mike Boos <mboos at augsignals.com> wrote:
>>>>>>Hello
>>>>>>I'm trying to run Mapscript using the SWIG C# bindings on an ASP.NET
>>>>>>server. I compiled the 4.6.0 version of MapServer and have placed
>what I
>>>>>>believe to be the appropriate dependencies (mapscript_csharp.dll,
>>>>>>mapscript.dll, libmap.dll, bgd.dll, gdal12.dll, pdflib.dll) in the bin
>>>>>>directory on my server. It is appears to be finding
>>>>>>mapscript_csharp.dll, but is having trouble finding mapscript.dll or
>one
>>>>>>of its dependencies. I am seeing the following error message:
>>>>>>Server Error in '/' Application.
>>>>>> /Unable to load DLL (mapscript)./
>of
>>>>>>* Exception Details: *System.DllNotFoundException: Unable to load DLL
>>>>>>(mapscript).
>>>>>>Am I missing a dependency? Or do I need to set some configuration
>option
>>>>>>or place the files elsewhere?
>>>>>>Thanks!
>>>>>>Mike Boos
