Python mapscript
Sean Gillies sgillies at FRII.COM
Mon Aug 22 11:23:17 EDT 2005
Robert,
Howard is packaging the Python modules differently, and I approve of
his choice. Try the following:
     from mapscript import mapscript
     mapfile = "Bob.map"
     map_bob = mapscript.mapObj(mapfile)
Sean
On Aug 22, 2005, at 8:57 AM, Brundage, Robert G wrote:
> Sean:
> I installed the HoBu Python.
> I still get the same error.
> The whole error is:
> Traceback (most recent call last):
> File
> "C:\Python24\Lib\site-packages\pythonwin\framework\scriptutils.py",
> line 310, in RunScript
>  exec codeObject in__main__.__dict__
> File "C:\ms4w\Apache\htdocs\map1.py", line 11 in ?
>   Mapobject - mapscript.mapObj(mapfile)
> AttributeError: 'module' object has no attribute 'mapObj'
> Below is mapfile
>>  	Import mapscript
>> 	mapfile = "Bob.map"
>> 	mapobect =  mapscript.mapObj(mapfile)
> Robert Brundage
> GIS Coordinator
> Department Public Works
> Fort Campbell, KY
> PH: 270-798-9571
> FAX: 270-798-2232
> -----Original Message-----
> From: Sean Gillies [mailto:sgillies at frii.com]
> Sent: Saturday, August 20, 2005 9:04 AM
> To: Brundage, Robert G
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: Python mapscript
> On Aug 19, 2005, at 2:07 PM, Brundage, Robert G wrote:
>> This message is in MIME format. Since your mail reader does not
>> understand
>> this format, some or all of this message may not be legible.
>> ------_=_NextPart_001_01C5A4F9.A6F92066
>> Content-Type: text/plain
>> Hello:
>> I am new Mapserver and following along in the 'Web Mapping
>> Illustrated' book
>> by Tyler Mitchell.
>> I cannot get the basic python script to run.
>>  	Import mapscript
>> 	mapfile = "Bob.map"
>> The above code gives an error:   AttributeError:  'module' object has
>> not
>> attribute 'mapObj'.
>> I am using Python Active build 245
> mapscript is not a standard Python module, and is not included with
> ActivePython. You will need to build it, or download a binary. Frank
> Warmerdam's FWTools contains mapscript for Python 2.3
>      http://fwtools.maptools.org
> and Howard Butler is doing something similar for Python 2.4
>      http://hobu.biz/software/hobutools
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com
