Donut Symbol.
Jeff Portwine
jdport at VERITIME.COM
Fri Aug 26 10:27:24 EDT 2005
I haven't tried this , so it may not work, I've always used filled in
shapes.. but couldn't you just use a non-filled in circle:
SYMBOL
NAME "circle"
TYPE ellipse
FILLED false
POINTS
1 1
END
END
and then set its size appropriately? I'm not sure if there is a good way
to affect the thickness though, other than stacking several of them with
varying sizes.
-Jeff
----- Original Message -----
From: "Bob Basques" <bob.basques at CI.STPAUL.MN.US>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, August 25, 2005 5:39 PM
Subject: [UMN_MAPSERVER-USERS] Donut Symbol.
> Does anyone know of a good way to make a donut symbol.
> I need to be able to resize a symbol that is basically a donut. Where the
> donut part is semi-opaque, and the center is open. It's basically a
> min/max distance from a point overlay. I have the dynamic handing off of
> the sizing handled already, but haven't figured out a good way to make a
> filled donut symbol.
> I did mange to make a stacked symbol, but I would really like to have the
> center no be filled in, only the area between the MIN/MAX distance from
> the point picked.
> Thanks
> bobb
