WFS and Oracle
Huub Fleuren
hfl at HOME.NL
Tue Aug 30 12:46:56 EDT 2005
I' m sorry to say that the trick to use an upgraded vc6sp6 .\Common and
.\vc98 did not yet do the trick.
I'm thinking dependencies now. I will rebuild from scratch.
A comforting thought is that we can use Howard Butler's fully featured
Oracle92 compile.
http://hobu.stat.iastate.edu/mapserver/
So, I'll keep on swimming for a while.
Thank you for the responses
Regards, Huub
Huub Fleuren wrote:
> oke
> results on monday.
> Regards, Huub
> Bart van den Eijnden wrote:
>> Huub,
>> you need to compile mapserv with VC6, SP3 or SP4 minimal (one of the
>> two, I can't remember exactly). Otherwise you get crashes on
>> GetFeatureInfo or GetFeature with maporaclespatial. VC7 also does the
>> trick.
