MapServer CGI : Url encoding of negative values for mapext parameter ?
Laurent Jégou jegou at UNIV-TLSE2.FR
Fri Dec 2 08:21:22 EST 2005
Hi, a simple question this time :
I'm generating 36x18 ten degrees squares maps with (UMN genuine)
MapServer, using php to generate <img src=" MapServer cgi calls. So i
use the cgi variable mapext=. Example of sch an url :
http://localhost/cgi-bin/mapserver.exe?mode=map&map=my_path_to_mapfile.map&mapext=10+40+20+50
But it's not working when negative values occurs, and since the spatial
reference is lat/long wgs84, there are some negatives...
Anyone can help me to find the right url syntax for the mapext paramater ?
Laurent Jégou
IGE Cartographe
UTM - Dépt. Géographie
31058 TOULOUSE Cedex 9 - 05.61.50.43.89
http://www.univ-tlse2.fr/geoprdc
http://www.geotests.net/blog
