drawing points from mysql with php/mapscript
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Dec 5 12:38:54 EST 2005
Mark,
In your code snippet you have (lat,lon) == (x,y) this is wrong, x=lon
and y=lat. Make that change and see if it helps.
-Steve W.
Mark Brooks wrote:
> I'm trying to draw points from a MySQL database onto a map with
> PHP/Mapscript. I found no clear examples online and so far have had
> little luck at being successful. Does anyone out there have any
> examples you could share?
> Here is part of my mapfile, which sets up an empty layer for the sites I
> want to draw on the map....
> LAYER
> NAME sites
> TYPE POINT
> STATUS DEFAULT
> CLASS
> NAME 'Project Sites'
> COLOR 150 150 150
> SYMBOL 'circle'
> SIZE 10
> LABEL
> TYPE truetype
> FONT "arial"
> SIZE 10
> POSITION UC
> COLOR 150 150 150
> END
> END
> END
> And a watered-down snippet from my php code to draw the dynamic points
> from mysql:
> $image = $map->draw();
> $this_layer = $map->getLayerByName('sites');
> $this_layer->set('status', MS_ON);
> //query database for points
> $query = "select bla bla";
> $sresult = mysql_query($query);
> // loop through database results, adding the new point to the layer
> while ($site = mysql_fetch_assoc($sresult)){
> $mypoint = ms_newPointObj();
> $mypoint->setXY($site['lat'],$site['lon']);
> $mypoint->draw($map,$this_layer,$image,0,$site['name']); }
> My site points are latitude,longitude. When I do all this, I only get
> ONE point drawn on my map. There are dozens of points but only one gets
> plotted, and I'm not entirely certain that it truly is a point from my
> database. I even hardcoded several different coordinates but only one
> dot appears on my map.
> What am I missing?
