drawing points from mysql with php/mapscript
Skalski Artur - askals
Artur.Skalski at ACXIOM.COM
Mon Dec 5 12:47:42 EST 2005
hi Mark
Currently I'm working on the same issue,
If You draw ponits from any data base like that you will not ba able to query them like the regular point layer, so if You want to query them you should use ogr
http://ogr.maptools.org/drv_vrt.html
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData,
any way this is how I have solved the problem of generating dynamic poinst from db:
mapfile layer:
LAYER
NAME selpoint
TYPE POINT
STATUS ON
#TRANSPARENCY 40
CLASS
NAME "0"
STYLE
COLOR 0 0 180
SYMBOL 'C:\Inetpub\wwwroot\mapserver\sopot\etc\tutaj.gif'
END
END
END
and the php code:
$MinX = doubleval($HTTP_FORM_VARS["minx"]);
$MinY = doubleval($HTTP_FORM_VARS["miny"]);
$MaxX = doubleval($HTTP_FORM_VARS["maxx"]);
$MaxY = doubleval($HTTP_FORM_VARS["maxy"]);
$_POST['ArrX'] = array(4340433.22, 4340245.38, 4342358.58); (the search results are stored in the array)
$_POST['ArrY'] = array(6037766.72, 6038377.20, 6037602.36);
SetMapExtents($MinX, $MinY, $MaxX, $MaxY); //it will not zoom the map out when you add them dymnamicaly, otherwise it does, a least in my case
for($i=0; $i<count($_POST['ArrX']); $i++)
$spoint = ms_newPointObj();
$spoint->setXY($_POST['ArrX'][$i], $_POST['ArrY'][$i]);
$slayer = $gpoMap->getLayerByName(selpoint);
$sline = ms_newLineObj();
$sline->add($spoint);
$sshape = ms_newShapeObj(MS_SHAPE_POINT);
$sshape->add($sline);
$slayer->addFeature($sshape);
and that's it
hope it helps
regards
Artur Skalski
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Mark Brooks
Sent: Monday, December 05, 2005 5:38 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] drawing points from mysql with php/mapscript
I'm trying to draw points from a MySQL database onto a map with
PHP/Mapscript. I found no clear examples online and so far have had
little luck at being successful. Does anyone out there have any
examples you could share?
Here is part of my mapfile, which sets up an empty layer for the sites I
want to draw on the map....
LAYER
NAME sites
TYPE POINT
STATUS DEFAULT
CLASS
NAME 'Project Sites'
COLOR 150 150 150
SYMBOL 'circle'
SIZE 10
LABEL
TYPE truetype
FONT "arial"
SIZE 10
POSITION UC
COLOR 150 150 150
END
END
END
And a watered-down snippet from my php code to draw the dynamic points
from mysql:
$image = $map->draw();
$this_layer = $map->getLayerByName('sites');
$this_layer->set('status', MS_ON);
//query database for points
$query = "select bla bla";
$sresult = mysql_query($query);
// loop through database results, adding the new point to the layer
while ($site = mysql_fetch_assoc($sresult)){
$mypoint = ms_newPointObj();
$mypoint->setXY($site['lat'],$site['lon']);
$mypoint->draw($map,$this_layer,$image,0,$site['name']); }
My site points are latitude,longitude. When I do all this, I only get
ONE point drawn on my map. There are dozens of points but only one gets
plotted, and I'm not entirely certain that it truly is a point from my
database. I even hardcoded several different coordinates but only one
dot appears on my map.
What am I missing?
Mark Brooks
Meteorologist
State Climate Office of North Carolina
Box 7236, NC State University
Raleigh, NC 27695-7236
E-mail: mark_brooks at ncsu.edu
Phone: 919.515.1446
Fax: 919.515.1441
The information contained in this communication is confidential, is
intended only for the use of the recipient named above, and may be
legally privileged.
If the reader of this message is not the intended recipient, you are
hereby notified that any dissemination, distribution or copying of this
communication is strictly prohibited.
If you have received this communication in error, please resend this
communication to the sender and delete the original message or any copy
of it from your computer system.
Thank you.
