Querying and labeling a WFS layer in Mapserver WFS client
frequens
frequens at GMAIL.COM
Thu Dec 8 12:12:14 EST 2005
On 12/8/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
> I haven't tried this myself but maybe you need to include the namespace in
> front of the column name, so myns:XXX_ID.
> What does ogrinfo report on your gml file? What are the names of the
> attributes when you check the summary with ogrinfo?
Bart, thank you for a good starting point:
the .gfs file is plain (perhaps too much :-):
<GMLFeatureClassList>
<GMLFeatureClass>
<Name>myns:xxxlayer</Name>
<ElementPath>myns:xxxlayer</ElementPath>
<DatasetSpecificInfo>
<FeatureCount>100</FeatureCount>
<ExtentXMin>386550.00000</ExtentXMin>
<ExtentXMax>615920.00000</ExtentXMax>
<ExtentYMin>35030.00000</ExtentYMin>
<ExtentYMax>186900.00000</ExtentYMax>
</DatasetSpecificInfo>
<PropertyDefn>
<Name>myns:XXX_ID</Name>
<ElementPath>myns:XXX_ID</ElementPath>
<Type>Integer</Type>
</PropertyDefn>
</GMLFeatureClass>
</GMLFeatureClassList>
The ogrinfo output of the .gml is even more plain (so there is clearly
something wrong):
1. myns:xxxlayer
The EPSG ows_metadata keyword is defined on the map level and present in the
.gml file, but not spit out in .gfs file (should it be?).
So much for now,
BR
frequens
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051208/894c3c64/attachment.html
