Querying and labeling a WFS layer in Mapserver WFS client
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Dec 8 12:15:32 EST 2005
For ogrinfo you have to do something like:
ogrinfo thefile.gml myns:xxxlayer -summary
It seems to me the property names include the namespace, so you should use the full names in LABELITEM etc. Did you try that?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> frequens <frequens at gmail.com> 12/08/05 6:12 PM >>>
On 12/8/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
> I haven't tried this myself but maybe you need to include the namespace in
> front of the column name, so myns:XXX_ID.
> What does ogrinfo report on your gml file? What are the names of the
> attributes when you check the summary with ogrinfo?
Bart, thank you for a good starting point:
the .gfs file is plain (perhaps too much :-):
<GMLFeatureClassList>
<GMLFeatureClass>
<Name>myns:xxxlayer</Name>
<ElementPath>myns:xxxlayer</ElementPath>
<DatasetSpecificInfo>
<FeatureCount>100</FeatureCount>
<ExtentXMin>386550.00000</ExtentXMin>
<ExtentXMax>615920.00000</ExtentXMax>
<ExtentYMin>35030.00000</ExtentYMin>
<ExtentYMax>186900.00000</ExtentYMax>
</DatasetSpecificInfo>
<PropertyDefn>
<Name>myns:XXX_ID</Name>
<ElementPath>myns:XXX_ID</ElementPath>
<Type>Integer</Type>
</PropertyDefn>
</GMLFeatureClass>
</GMLFeatureClassList>
The ogrinfo output of the .gml is even more plain (so there is clearly
something wrong):
1. myns:xxxlayer
The EPSG ows_metadata keyword is defined on the map level and present in the
.gml file, but not spit out in .gfs file (should it be?).
So much for now,
BR
frequens
