Question about OFFSET values
Blammo
bob.basques at CI.STPAUL.MN.US
Sat Dec 10 13:49:34 EST 2005
> I guess I need to try this. So I assume that the offsets work relative
> to the rotated label and not the image X-Y axis. Cool, I just noticed
> that you have MULTIPLE labels for a single layer. I didn't know you
> could do that. ... I love mapserver!!!
Actually they are all seperate layers right now. Sorry about the confusion.
bobb
> Thanks,
> -Steve
>> LABEL
>> ANGLE AUTO
>> POSITION LL
>> TEXT "[L_FROM]"
>> OFFSET 10 5 ## it's interesting that these numbers don't need to
>> be negative like I thought at first.
>> END
>> LABEL
>> ANGLE AUTO
>> POSITION UL
>> TEXT "[L_TO]"
>> OFFSET 10 5
>> END
>> LABEL
>> ANGLE AUTO
>> POSITION LR
>> TEXT "[R_FROM]"
>> OFFSET 10 5
>> END
>> LABEL
>> ANGLE AUTO
>> POSITION UR
>> TEXT "[R_TO]"
>> OFFSET 10 5
>> END
>> bobb
>> Stephen Woodbridge wrote:
>>> Hi Bob,
>>> Would you post what you have done so far? I have wanted to do
>>> something like this for a long while.
>>> Have you, would you open a bug for an enhancement to mapserver to
>>> better support this functionality?
>>> You might be able to get this to work with two layers by:
>>> LABEL
>>> ANGLE AUTO
>>> POSITION CC
>>> TEXT "[L_FROM] [R_FROM]"
>>> WRAP " "
>>> END
>>> Then you can vary the number of spaces between the two fields based
>>> on the line thickness and then use the OFFSETs to get them
>>> positioned on the line.
>>> It would be nice if POSITION could take a percentage along the line
>>> segment as the label point. So 0.0 would be the start of the line
>>> and 1.0 would be the end of the line and the angle would be based on
>>> which part of the polyline that the label point fell on.
>>> -Steve W.
>>> Bob Basques wrote:
>>>> All,
>>>> Ok, I got my addressing range labels too llok pretty good using
>>>> four Layers with seperate LABELITEMS and OFFSETS.
>>>> Now I need to figure out a way, if possible, to scale the OFFSET
>>>> values based on the overall length of the line.
>>>> Can I use a value, line length, and a percentage of line length to
>>>> use for the Offset values of the labels. Right now the labels are
>>>> situated for the most part near the center of the line. I would
>>>> like to puch the labels out to the ends of the lines for example,
>>>> or pull them in closer for longer and shorter line segments.
>>>> This is purely an exercise in readability right now, what I have
>>>> seems to be working great for the customer. Thanks for the
>>>> pointers I got last week.
>>>> bobb
