Little Help - C#
Sean Gillies
sgillies at FRII.COM
Thu Dec 15 11:18:33 EST 2005
Ian,
Down in the heart of the MapServer code, style.symbol is all that
counts. The symbolname attribute is (only) for convenience. The
closest thing we have in mapscript now is
symbol_index = map.symbolset.index("some_name")
style.symbol = symbol_index
cheers,
Sean
On Dec 15, 2005, at 9:03 AM, Ian Erickson wrote:
> Alright,
> Got it working - Thanks! The following code is what I ended up
> using -
> in case anyone else needs it. Also, I noticed that the styleObj does
> not seem to work properly when using the symbolname property. I was
> forced to user the symbol index instead. Any reason why this might
> be?
> Code follows:
> mapObj m_obj = new mapObj(@"C:\base.map");
> layerObj layer = new layerObj(m_obj);
> layer.name = "PointLayer";
> layer.type = MS_LAYER_TYPE.MS_LAYER_POINT;
> layer.setProjection("init=epsg:4326");
> layer.status = 1;
> classObj c = new classObj(layer);
> c.name = "MARKER";
> c.label.type = MS_FONT_TYPE.MS_TRUETYPE;
> c.label.font = "arial";
> c.label.size = 7;
> c.label.color.setRGB(0, 0, 0);
> c.label.outlinecolor.setRGB(255, 255, 255);
> styleObj style = new styleObj(c);
> style.symbol = 7;
> // style.symbolname = "circle";
> style.antialias = 1;
> style.minsize = 12;
> style.maxsize = 12;
> style.size = 12;
> style.color.setRGB(192, 0, 0);
> style.outlinecolor.setRGB(255, 0, 0);
> imageObj i_obj = m_obj.draw();
> pointObj p = new pointObj(-111.4752, 33.377321, 0.0, 0.0);
> Console.WriteLine("p.x = " + p.x);
> Console.WriteLine("p.y = " + p.y);
> p.draw(m_obj, layer, i_obj, 0, "TEXT");
> p.Dispose();
> try
> i_obj.save(@"C:\output.png",m_obj);
> } catch (Exception e)
> Console.Writeln(e.printStackTrace());
> Sean Gillies wrote:
>> On Dec 14, 2005, at 8:13 PM, Ian Erickson wrote:
>>> Alright,
>>> I've compiled a working version of the mapscript_csharp assembly and
>>> everything seems to be working fine. I can load, enumerate the
>>> layers,
>>> and save a copy of the image to the file system. However, I
>>> need to
>>> add
>>> a point to a dynamically created layer (all of this mind you in C#).
>>> Here's what I've got:
>>> layer.status = 1;
>>> c.label.size = 7;
>>> style.size = 14;
>>> style.color.setRGB(0, 255, 0);
>>> style.outlinecolor.setRGB(0, 0, 0);
>>> Console.WriteLine ("# Map layers " + m_obj.numlayers + ";
>>> Map
>>> name = " + m_obj.name);
>>> for (int i=0; i<m_obj.numlayers; i++)
>>> Console.WriteLine("Layer [" + i + "] name: " +
>>> m_obj.getLayer(i).name);
>>> lineObj l = new lineObj();
>>> l.add(p);
>>> shapeObj s = new shapeObj(0);
>>> s.add(l);
>>> s.text = "TEXT";
>>> layer.addFeature(s);
>> Ian,
>> The last two lines here are redundant. There are 3 different ways to
>> render a point.
>> 1) pointObj#draw
>> 2) shapeObj#draw
>> 3) layer#addFeature and then layer#draw
>> You're doing a little bit of each. I recommend that you go with #1
>> and delete the lines in between the creation of the new point, and
>> p.draw().
>>> s.Dispose();
>>> l.Dispose();
>>> p.Dispose();
>>> Console.ReadLine();
>>> As I mentioned, the assembly is creating the appropriate file, and
>>> everything seems to be working - with the exception of creating
>>> a point
>>> symbol on the new layer. No exceptions are thrown so I must be
>>> missing
>>> something crucial. If anyone can provide some hints, I'd be
>>> grateful!
>> How do you know that points are not drawn? Are you saving the
>> imageObj? I can't tell from the code.
>> Sean Gillies
>> sgillies at frii dot com
>> http://zcologia.com/news
> Ian Erickson
> AnalyGIS, LLC
> Gold Canyon, AZ 85218
> http:// www.analygis.com
> tel: 480.677.6260
> mob: 480.221.7173
> fax: 480.677.6261
> See AnalyGIS at work:
> http://65.39.85.13/google/
> http://65.39.85.13/virtualearth/
Sean Gillies
