Using class annotation angles
Don Isgitt
djisgitt at SOUNDENERGY.COM
Mon Dec 19 14:10:22 EST 2005
I am attempting to display some text at specified angles using
labelangleitem, but no text plots. Without the font and type
specifications, text is plotted, but at zero degrees. Here is the
relevant data:
> MAP
> NAME "Area of Interest"
> STATUS ON
SIZE 1800 1260
> IMAGETYPE png
> extent 1140000 -140000 1930000 940000
> CONFIG PROJ_LIB /home/djisgitt/proj-4.4.9/nad
> fontset /usr/local/apache2/htdocs/gdsmap/font.list
> UNITS kilometers
> PROJECTION
> "init=epsg:32039"
> END
> layer
> name survey_ann
> data area_s
> status off
> PROJECTION
> "init=epsg:4283"
> END
> type annotation
> force true
> labelitem "Survey"
> labelangleitem "SvyAng"
> class
> # color 232 232 232
> outlinecolor 0 255 255
> label
> font cetus
> type TrueType
> position ul
> size tiny
> antialias true
> color 219 149 8
> partials off
> end
> end
> end
Other layers of type polygon and line fail similarly.
Sample output of dbfdump:
Survey SvyAng Block BlkAng Section
SecAng CntyNam
TCRR 0000 IJ 0000 43
0000 (NULL)
JORDAN MW 0000 BB2 0000 7
0000 (NULL)
BURLESON J 0015 37 T2S 0000 (NULL) 0000 J
IRR 0015 A288 0000 1
0015 (NULL)
(NULL) 0000 L CRCK 0000 3
0000 (NULL)
FUENTES AM 0045 (NULL) 0000 139
0045 (NULL)
HOPE WT 0040 4.5 0000 1
0040 (BLK. 4 1/2)
Any help explaining what I am doing wrong will be much appreciated.
Don
p.s. Mapserver 4.6.1 on Linux compiled from source.
