Mapeserver CGI
Sylvain Beorchia
sbeorchia at GI-LEMANS.COM
Thu Dec 22 08:06:45 EST 2005
I'm not sure to well understand what you want to do.
What sort of data do you need from your database ? and what for ?
If you want to create a small application for managing maps and data, for sure Mapserver cannot do the whole thing. You'll need to code a few in PHP for example to do what you want. But yes you may retreive some data via the mapfile, for example if you want to display attributes of a shape as a label....
Thanks.
Sylvain B.
(please reply with the mailing list in copy)
----- Original Message -----
To: sbeorchia at GI-LEMANS.COM
Sent: Thursday, December 22, 2005 1:46 PM
Subject: Mapeserver CGI
Hi ,
Wanted to know if what we're thinking is rite :: There is not much difference between using Mapserver CGI directly or using Mapserver with Php scripting . The only diff we see is that using Php Mapscripting u can script in Php with HTML.Hence for creating dynamic maps , even if Mapscripting modules are not used is it sufficient ?
Also if i have to read data from MySql and use it in Mapserver , will it be done with the help of CONNECTION strings (in layers in the map file) ?
Thanking You ,
Apeksha
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051222/e428f4d6/attachment.html
