configure issues SUSE 9.1
Vladimir Guzmán bigfoot at MAIN-TASK.COM
Tue Feb 1 09:01:56 EST 2005
Try installing the devel package of php.
It contains the necessary headers.
Vladimir Ilich Guzmán R.
http://maintask.com
Frank Barrett wrote:
>Hello all,
>I have a working version of mapserver running on my linux box.
>Unfortunately I didnt initially configure mapserver with PHP/Mapscript i.e.
>(--with-php).
>Now when I try the configure i.e.:
>./configure --with gdal=/usr/local/bin/gdal-config --with
>ogr=/usr/local/bin/gdal-config --with-gd --with-proj --with-php=/usr/bin
>I get the following:
>configure: checking for PHP/Mapscript module options...
>checking for g++ -shared ... yes
>       using 'g++ -shared' for dynamic linking
>checking for locations of config.h or php_config.h... configure: error:
>!!! Could not fin config.h or php_config.h in /usr/bin.                !!!
>!!! Has PHP been configured yet?                                      !!!
>I have php 4.3.4 running on my machine which was installed sucessfully
>using the suse 9.1 distro. The config.h/php_config.h files do not appear to
>be on my system (i.e. I have no joy following a search)? I have given the
>path to the /usr/bin i.e. the path to the location of the php executable
>file. I see from the mapserver wiki site i.e. at
>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RedHat9AndMapserver40 that the
>user downloaded and installed a second version of php 4.3.4. Specifically
>for(?) mapserver. Is this really necessary? Or can any users suggest a
>workaround so something so I can get PHP/Mapscript up and working.
>Thanks in advance for you time.
>Frank.
