ECW Image Shift
Eric Lowrance
eblowrance at BPA.GOV
Tue Feb 1 17:15:52 EST 2005
Hi all,
I have about 30 tiled ECW images in WGS84 that exhibit a x-shift of about
50m when compared to the originals and other WGS84 map services (Like
Terraserver) and other data sources. This same shift appears in both my
web browser application and ArcMap, so it seems as if MapServer or my
configuration is the culprit. If I bring one of the tiled images in ArcMap
it lines up just fine with all of my other data sources. I'm a MapServer
novice, so any suggestions would be appreciated, thanks!
MAP
NAME NATURALVIEW
IMAGETYPE png24
EXTENT -126.001390 39.99844 -107.99847 55.00139
SHAPEPATH "W:\data\NVECW\"
OUTPUTFORMAT
NAME PNG24
DRIVER "GD/PNG"
MIMETYPE "image/png"
EXTENSION PNG
IMAGEMODE RGBA
TRANSPARENT ON
END
WEB
METADATA
WMS_TITLE "NaturalVue_Imagery"
WMS_ONLINERESOURCE "http://..."
WMS_SRS "EPSG:4326"
END
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME "NaturalVue"
METADATA
"wms_title" "NaturalVue_Imagery"
"wms_srs" "EPSG:4326"
"wms_name" "NaturalVue"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/jpeg image/png24"
"wms_format" "image/png"
END
STATUS ON
TILEINDEX "nv_index.shp"
TILEITEM "location"
TYPE RASTER
END
