MapServer crash
Laurent Jégou jegou at UNIV-TLSE2.FR
Wed Feb 2 14:19:27 EST 2005
Hello, i've a problem puzzling me for quite a long time, and after
checking many potential solutions i seek your advice.
When i use php_mapscript the map is generated, but when i use the
mapserv directly in an url or a html file, it crashes with the infamous
"premature end of script headers" in apache server error.log.
Here you can test that, with the tutorial files :
http://serv-1-3-69.lycos-vds.com/tutorial/test1.php
http://serv-1-3-69.lycos-vds.com/cgi-bin/mapserv40?map=/var/www/tutorial/example1-1.map&mode=map
The server is a debian woody linux fresh installed, phpinfo on
http://serv-1-3-69.lycos-vds.com/info.php, the server root is /var/www,
the tutorial dir and files are readable.
Any suggestion ? Thanks !
Laurent Jégou
IGE Cartographe
UTM - Dépt. Géographie
31058 TOULOUSE Cedex 9 - 05.61.50.43.89
