Can you find intersecting polygons?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Feb 2 14:22:01 EST 2005
Steve Lehr wrote:
> Is it possible to find intersecting polygons with PHP Mapscript? (or other
> if not)
> I'm thinking I'd like to use the JAVA front so that a user can select a
> random polygon on the screen, then submit the random polygon. Behind the
> scenes convert those points to extent type coordinates, generate a polygon,
> then find the interersecting polygons underneath.
I may be wrong, but I think you can do a query to get the polygon and
then do a subsequent queryByShape to get the underlying objects.
-Steve W.
