MapServer crash
Colin McGuigan
cmcguigan at EARTHCOMBER.COM
Wed Feb 2 17:22:53 EST 2005
Laurent Jégou wrote:
> Hello, i've a problem puzzling me for quite a long time, and after
> checking many potential solutions i seek your advice.
> When i use php_mapscript the map is generated, but when i use the
> mapserv directly in an url or a html file, it crashes with the infamous
> "premature end of script headers" in apache server error.log.
> Here you can test that, with the tutorial files :
> http://serv-1-3-69.lycos-vds.com/tutorial/test1.php
http://serv-1-3-69.lycos-vds.com/cgi-bin/mapserv40?map=/var/www/tutorial/example1-1.map&mode=map
I had this problem when I compiled mapserver --with-php and
--with-php-regex.
Although I didn't need mapserv as a CGI, I did find that I could compile
mapserver with the PHP options to get a working php_mapscript.so, and
then compile mapserver without the PHP options to get a working mapserv
executable.
--Colin McGuigan
