Finding which shape polygon a point is in with mapscript
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Feb 2 17:31:00 EST 2005
Well that is one way to attempt this feat, the other way would be to
queryByPoint the polygon layer and let mapserver do the heavy lifting
for you. I thought there were some example mapscript code for doing
queries on the wiki or the website, but I couldn't find them doing a
quick browse of it.
Can someone point Camden at some examples of mapscript queries.
-Steve W.
Camden Daily wrote:
> Why is everything so much harder than it seems?
> I'm trying to take a point, and find which shape within a polygon
> layer contains that point.
> The code I'm using is this:
> function get_containing($layer, $longitude, $latitude) {
> global $map;
> $point = ms_newPointObj();
> $point->setXY($longitude, $latitude);
> $layer = $map->getLayerByName($layer);
> $layer->open();
> for ($i=0; $layer->getShape(-1, $i) != -1; $i++) {
> $shape = $layer->getShape(-1, $i);
> if ($shape->contains($point)) {
> $layer->close();
> return $shape; }
> $layer->close();
> return -1;
> and the map layer I'm using is school districts:
> LAYER
> NAME "school_elm"
> TYPE POLYGON
> STATUS OFF
> DATA "tgr17031elm"
> TEMPLATE dummy
> PROJECTION
> "init=epsg:4326"
> END
> END
> The error I receive (on the line that calls getShape):
> Fatal error: [MapServer Error]: msLayerGetShape(): Shapefile layer
> has not been opened.
> Which doesn't make much sense, as I'm calling layer->open and it
> doesn't return an error on that.
> Can anyone see something wrong with this, or tell me an effective way
> to loop through all of the shapes within a layer? Is there a way to
> get the number of shapes in a layer?
> -Camden Daily
