Rotated Orthographic View?
    Ed McNierney
    ed at TOPOZONE.COM
    Thu Feb  3 10:30:06 PST 2005
Your description is a little confusing.  Why do you need to rotate it
into the "right position"?  What's wrong with the original position?  If
it's "wrong", are you simply trying to generate a different projection
than the orthographic?
MapServer should be able to project your original shapefiles from any
projection to your desired output.  I don't see any reason why you'd
need to modify the shapefiles from the original lat/lon distribution
format.
You simply need to be able to accurately describe the desired output
projection.  Please give us the complete details of the orthographic
projection you're choosing in ArcMap.
     - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of H Z
Sent: Thursday, February 03, 2005 12:36 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Rotated Orthographic View?
I have a US lower 48 state/county map view in ESRI ArcMap that I have
exported shapefiles out of, and use them in MapServer/PerlMapScript to
generate maps for the Web.  When using a Mercator projection, everything
works fine, but now I need to use an orthographic projection.  When
using ortho in ArcMap, the map appears rotated, but I can use ArcMap's
Rotate Data Frame tool to get it in the right position.  Exporting the
rotated map to a shapefile and processing it in MapServer/PerlMapScript
however doesn't maintain the corrected rotation.
How can I have MapServer/PerlMapScript rotate the map prior to
generating an image from it?
Thanks!
More information about the MapServer-users
