UNC Paths
    Frank Warmerdam
    fwarmerdam at GMAIL.COM
    Thu Feb  3 11:40:38 PST 2005
On Thu, 3 Feb 2005 13:26:51 -0500, Ed McNierney <ed at topozone.com> wrote:
> Dan -
> Well, yes <g>.  You need to find and understand the corresponding user
> security model for Apache, then.  Everything runs under a user security
> context in Windows, so you need to know what user that is and what
> rights that user has.
> As Frank pointed out, however, there may be some issues with UNC support
> in MapServer, so you should confirm that first.  I stopped using UNC
> support several years ago because there were some serious limitations in
> MapServer at the time.  In particular, MapServer would change to a
> "current directory" (chdir()) and access files from there, and you can't
> have a current directory on a UNC path.
Folks,
First, please disregard my last message.  It seems I forgot how to
call fopen().  I passed "t" for the access instead of "r" or perhaps "rt".
Very embarrassing, and thanks to Norman Vine for pointing it out me.
I have done a couple more tests, and indeed OGR seems to
support access off an unmounted network drive.  The following
worked fine for me for instance.
  ogrinfo  \\gdal\warmerda\data\mapinfo\mills.mid
as did:
  ogrinfo //gdal/warmerda/data/mapinfo/mills.mid
Also, I don't believe that MapServer does any of that evil chdir()
stuff anymore.  So you should only have to deal with the permissions
issues that Ed raised.
Best regards,
More information about the MapServer-users
