UNC Paths
Ed McNierney
ed at TOPOZONE.COM
Thu Feb 3 15:02:03 EST 2005
Frank -
It is my recollection that all that chdir() stuff was fixed a long time
ago, too. I just haven't used it in a very long time, so I'm not a
reliable witness on that front!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Frank Warmerdam
Sent: Thursday, February 03, 2005 2:41 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] UNC Paths
On Thu, 3 Feb 2005 13:26:51 -0500, Ed McNierney <ed at topozone.com> wrote:
> Dan -
> Well, yes <g>. You need to find and understand the corresponding user
> security model for Apache, then. Everything runs under a user
> security context in Windows, so you need to know what user that is and
> what rights that user has.
> As Frank pointed out, however, there may be some issues with UNC
> support in MapServer, so you should confirm that first. I stopped
> using UNC support several years ago because there were some serious
> limitations in MapServer at the time. In particular, MapServer would
> change to a "current directory" (chdir()) and access files from there,
> and you can't have a current directory on a UNC path.
Folks,
First, please disregard my last message. It seems I forgot how to call
fopen(). I passed "t" for the access instead of "r" or perhaps "rt".
Very embarrassing, and thanks to Norman Vine for pointing it out me.
I have done a couple more tests, and indeed OGR seems to support access
off an unmounted network drive. The following worked fine for me for
instance.
ogrinfo \\gdal\warmerda\data\mapinfo\mills.mid
as did:
ogrinfo //gdal/warmerda/data/mapinfo/mills.mid
Also, I don't believe that MapServer does any of that evil chdir() stuff
anymore. So you should only have to deal with the permissions issues
that Ed raised.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
