Problem with POINT layer in PostGIS
Dirk Jesko
jesko at GEOCONTENT.DE
Fri Feb 4 11:06:14 EST 2005
The log file shows no problem. Further, if I take the logged query and
execute it within the psql shell it produces the correct result and the
log is not significantly different. I still suppose that it is not a
PostgreSQL/PostGIS problem.
Dirk
>Turn full logging on in PostgreSQL, attempt to render the map and see if it
>provides any further information...
>Drew.
