Frustration setting in.. Plotting a single point...
Ed McNierney
ed at TOPOZONE.COM
Fri Feb 4 23:06:55 EST 2005
Jeff -
Sorry if I'm tuning in late, but I'm not exactly sure what the symptom
you're seeing is.
However, your EXTENT:
EXTENT -2526068.80 3808293.58 2601312.92 930341.78
Is wrong, as it needs to be minX, minY, maxX, maxY and your minY is
larger than your maxY.
There's nothing especially huge about those extents, and I don't see why
there should be a problem with them, if you put them in the right order.
- Ed
Ed McNierney
TopoZone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jeff Cotterman
Sent: Friday, February 04, 2005 8:41 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Frustration setting in.. Plotting a
single point...
I'm sure this is something very simple, and I have gone through the
archives, and have copied numerous examples, the only thing I think can
be
causing a problem is the huge extents of my shape file, and the point
not
being converted correctly? There are two shapefiles for the US, and
state
borders..
Anyway, here is my php file (which should look almost identical to the
many
examples given) and my map file, any pointers would be greatly
appreciated.
I have tried it with and without the setProjection also..
<?php
//Load the dynamic library.
dl('php_mapscript.so');
// create our map object
$map_file = "basic.map";
$map = ms_newMapObj($map_file);
// create a temp layer to hold our points
$point_layer = ms_newLayerObj($map);
$point_layer->set("name", "markers");
$point_layer->set("type", MS_LAYER_POINT);
$point_layer->set("status", MS_DEFAULT);
$point_layer->setProjection("proj=latlong",MS_TRUE);
// create a class and style for this layer
$point_class = ms_newClassObj($point_layer);
$point_style = ms_newStyleObj($point_class);
$point_symbol = $map->getSymbolByName("point");
$point_style->set("symbol", $point_symbol);
$point_style->set("size", 20);
// draw our image without the points
$image = $map->draw();
// initialize our point and add it to the map
$point = ms_newPointObj();
$longitude="-149.0300";
$latitude="61.5600";
$point->setXY($longitude, $latitude);
$point->draw($map, $point_layer, $image, 0, "");
// get the location for our new image
$tmp_png_file = $image->saveWebImage (MS_PNG, 0, 0, 0);
exec ("mv ".$tmp_png_file." "."/home/cotterj/test.png");
MAP
DEBUG on
SIZE 410 240
SHAPEPATH /home/cotterj/shp/
IMAGECOLOR 255 255 255
PROJECTION
"proj=lcc"
"lat_0=18"
"lat_1=18"
"lon_0=-93"
"k_0=1"
"x_0=350000"
"y_0=150000"
"ellps=GRS80"
END
WEB
IMAGEPATH /home/cotterj/map
IMAGEURL /home/cotterj/map
END
LAYER
NAME "usa"
DATA county
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4269"
END
CLASS
NAME "base conus"
COLOR 255 255 255
END
END
LAYER
NAME "State Outlines"
DATA state
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4269"
END
CLASS
NAME "usa"
OUTLINECOLOR 102 102 102
END
END
END # end of map file
Once again any help or things to try would be appreciated! I think I
have
tried ever incarnation in the archives!
Cheers,
Jeff
