two labels for one polygon
Bart van den Eijnden bartvde at XS4ALL.NL
Mon Feb 7 05:08:24 EST 2005
could this be a problem with the label cache?
Can you try with LABELCACHE OFF on your LAYER which contains the labels?
Could you provide us with a screendump of the problem?
Best regards,
Bart
> I have a problem with showing labels of polygons in Oracle
> Spatial/mapserver environment. I have polygons and their labels defined in
> the same layer group. The following happens: if I add a polygon to the
> database the polygon will be shown with 2 times the same label. If I add a
> new polygon, the old polygon will be shown now with one label and the new
> polygon with two labels again. Any idea?
> Erwin
