two labels for one polygon
Fernando Simon
fsimon at UNIVALI.BR
Mon Feb 7 12:23:29 EST 2005
Besides this can be another problem, your layer data can be return
a wrong point. Your polygon plus a single point. How did you define
your layer data? If you execute your data string in SqlPlus how many
rows return?
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratório de Computação Aplicada - UNIVALI/CTTMar
http://g10.cttmar.univali.br
Citando Bart van den Eijnden <bartvde at XS4ALL.NL>:
> Hi,
> could this be a problem with the label cache?
> Can you try with LABELCACHE OFF on your LAYER which contains the
> labels?
> Could you provide us with a screendump of the problem?
> Best regards,
> Bart
> > I have a problem with showing labels of polygons in Oracle
> > Spatial/mapserver environment. I have polygons and their labels
> defined in
> > the same layer group. The following happens: if I add a polygon
> to the
> > database the polygon will be shown with 2 times the same label.
> If I add a
> > new polygon, the old polygon will be shown now with one label and
> the new
> > polygon with two labels again. Any idea?
> > Erwin
Univali - Webmail - http://webmail.univali.br
