postgis error
Shashi Gireddy gireddy at GMAIL.COM
Mon Feb 7 12:38:28 EST 2005
Thanks for your help, Thannks a lot. DATA "the_geom from counties using SRID=-1"
 this line helped me.
shashi.
On Mon, 07 Feb 2005 16:27:23 +0100, car271 at tiscali.it <car271 at tiscali.it> wrote:
> Shashi Gireddy wrote:
> >Yes, I checked all columns, they are looking fine, and the_geom row
> >contains srid also, but somehow mapserver is not recognising it. Is
> >just 'the_geom' row is required to draw a shape image or any other
> >rows are also required to do this.
> >thank you.
> >On Fri, 04 Feb 2005 16:04:50 -0800, Paul Ramsey <pramsey at refractions.net> wrote:
> >>This would appear to be good advice. Have you confirmed that your
> >>geometry column does in fact appear correctly in geometry_columns?
> >>P
> >>On 4-Feb-05, at 2:23 PM, Shashi Gireddy wrote:
> >>>Postgresql reports the error as 'ERROR: find_srid() - couldnt find the
> >>>corresponding SRID - is the geometry registered in the
> >>>GEOMETRY_COLUMNS table? Is there an uppercase/lowercase missmatch? '
> >Shashi Kiran Reddy. Gireddy,
> >Graduate Assistant,
> >CBER, University of Alabama.
> >http://www.cs.ua.edu/shashi
> >Home: 205-752-5137 Cell: 205-657-1438
> Hi,
> try to write in your map file that:
> Good luck.
> Make me know if you solve.
> Bye
Graduate Assistant,
