Problem with POINT layer in PostGIS
Dirk Jesko jesko at GEOCONTENT.DE
Mon Feb 7 08:42:36 EST 2005
Hi Perry,
I am now pretty sure that this problem only occurs with newer PostGIS
versions. Today I replaced PostGIS 1.0.0RC2 by an older one (0.9.0) and
it worked fine with all mapserver versions from 4.0 up to 4.5. On the
other hand neither mapserver version works with 1.0.0RC2, i.e. only
lines and polygons are drawn, but points are not.
Which version of PostGIS are you using? If you also have 1.0.0RCx (or
maybe 0.9.1 which I did not check), it is most likely an incompatibility
of the newer PostGIS versions and mapserver. Maybe you could also try an
oder version to see if you can confirm it.
Dirk
>I submitted a bug for this (#1216).  I have a table with point geoms and
>another with polygon geoms.  The polygon table displays as polygon, line, and
>points.  The point table doesn't display at all.
>When converted to shapefile using pgsql2shp, the points display fine.
>However, I need the database as it will be updated continually via a web
>interface.  The shapefile is not an option for me.
>I've checked against 4.2.5, 4.4.1 and the CVS versions of MapServer and
>neither would display the points.  All the queries run properly in psql and
>pgadmin.
>-Perry
