Problem with POINT layer in PostGIS
Dirk Jesko jesko at GEOCONTENT.DE
Mon Feb 7 02:35:36 EST 2005
Thanks. I just remembered that I had POINT-layers working with older
versions of PostgreSQL, PostGIS and Mapserver. I am not sure, but I
think it was PostgreSQL 8.0.0beta5, PostGIS 0.9.0 and Mapserver 4.2.1.
Also, I now think that I remember reading something in the postgis-users
list about problems with Mapserver POINT-layers and the RC-Versions of
PostGIS 1.0.0. Unfortunately, I can not find the thread anymore.
Dirk
P.S.: I also added this comment to the bug report.
>I submitted a bug for this (#1216).  I have a table with point geoms and
>another with polygon geoms.  The polygon table displays as polygon, line, and
>points.  The point table doesn't display at all.
>When converted to shapefile using pgsql2shp, the points display fine.
>However, I need the database as it will be updated continually via a web
>interface.  The shapefile is not an option for me.
>I've checked against 4.2.5, 4.4.1 and the CVS versions of MapServer and
>neither would display the points.  All the queries run properly in psql and
>pgadmin.
>-Perry
