Dynamic layers list
Bart van den Eijnden bartvde at XS4ALL.NL
Tue Feb 8 04:38:29 EST 2005
how is your list of layers generated? Using the HTML legend option of
Mapserver?
If this is the case, you can use the keyword layer_visible to filter out
layers which are really in the map view at the current map scale.
See also:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=648
Best regards,
Bart
> I have installed Mapserver 4.4.0 on Fedora Core3.
> Because of  the layers of my webgis are visible at different scales, I
> would like to have a dynamic "Layers List" (with layers in the list only
> when they are really visible) instead of  the non-dinamic list I  have
> got using  MapLab.
> Can you help me?
> Thanks a lot
> Vinicio Balducci
> Vinicio Balducci
> Consiglio Nazionale delle Ricerche
> Istituto di Ricerca per la Protezione Idrogeologica
> Via Madonna Alta, 126
> 06128 Perugia
> Tel. +39 075 5014429/427
> Fax. +39 075 5014420
> E-mail: vinicio.balducci at irpi.cnr.it
> http://www.irpi.cnr.it/
