[UMN_MAPSERVER-USERS] map file access problems
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Wed Feb 9 10:42:41 EST 2005
Hi Mark,
Yes, you have to give IUSR_[NAME] permission tu read u:\wwwroot\ directory. If this is your main virtual web directory, IUSR_ should already have the right to read it. I use filemon tools to check for permission problem, you could find it here: http://www.sysinternals.com/ntw2k/source/filemon.shtml . While running it and getting the error, search for any ACCESS DENIED.
Nick
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Mark Andrle
Envoyé : Wednesday, February 09, 2005 10:23 AM
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] map file access problems
Hello,
I very new to mapserver and I'm having problems getting mapserver to access the map file.
When I execute http://s-cnbml350:8080/cgi-bin/mapserv.exe?
map=u:\wwwroot\home.map&mode=map I receive a message of msLoadMap(): Unable to access file. (u:\wwwroot\home.map)
We are using Windows XP and IIS. Could this be a permission problem?
Any suggestions would be much appreciated.
Thank You
Mark Andrle
