showing lines of overlapping polygons
John Fletcher
jfletcher at LATITUDEGEO.COM
Wed Feb 9 12:13:14 EST 2005
Erwin,
Something like the following might give you the result you're after -
like Frank mentioned, it's difficult to do this in one layer, but you
can group a couple:
LAYER
GROUP 'poly'
NAME 'poly_test_outline'
TYPE POLYGON
STATUS ON
DATA 'poly23939'
CLASS
STYLE
OUTLINECOLOR 0 0 0
END
END
END
LAYER
GROUP 'poly'
NAME 'poly_test'
TRANSPARENCY 60
TYPE POLYGON
STATUS ON
DATA 'poly23939'
CLASS
STYLE
COLOR 225 225 185
END
END
END
You can change the order of the layers based on whether or not you want
the poly outlines in front of or behind the transparent poly fill.
John
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Erwin v.d. Bij
> Sent: Wednesday, February 09, 2005 4:26 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] showing lines of overlapping polygons
> Hello,
> I want to see the lines of 2 or more polygons which do
> overlap. Polygons are in the same layer. Polygons are filled
> with a style. Currently, I see only all the lines of the
> polygon which is obvious on top. I've experienced with the
> TRANSPARANCY attribute, but that did not help. Do you have any ideas?
