PostGIS vs. Shapefile
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Feb 10 07:23:03 EST 2005
see:
http://postgis.refractions.net/docs/ch04.html#id3125676
In short you can create the spatial index in the following way:
CREATE INDEX mytable_geom_idx ON mytable USING GIST (the_geom
GIST_GEOMETRY_OPS);
followed by:
vacuum analyze;
Best regards,
Bart
> Hmm...
> I'm new to PostGIS, I imported data from shapefile to POstGIS with these
> commands:
> # su - postgres
> $ createdb my_database
> $ createlang plpgsql my_database
> $ psql -d my_database -f /usr/share/pgsql/postgis.sql
> $ psql -d my_database -f /usr/share/pgsql/spatial_ref_sys.sql
> $ shp2pgsql /path_to_shapefiles/my_shapefile01 my_table01 | psql -d
> my_database
> (last command repeated for every shapefile).
> For every import, an index (I think) is created:
> NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index
> 'my_table01_pkey' for table 'my_table01'
> In my .map file I have:
> DATA "the_geom from my_table01"
> CONNECTION "user=postgres dbname=my_database host=localhost port=5432"
> CONNECTIONTYPE postgis
> Are the above steps correct?
> How can I check if I have a spatial index on my tables, and an index on
> the primary key of my tables?
> Thank you,
> Daniele
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Bart van den Eijnden
> Sent: Thursday, February 10, 2005 11:13 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] PostGIS vs. Shapefile
> Hi Daniele,
> No that's not normal.
> Do you have a spatial index on your table in PostGIS? Do you have an
> index on the primary key of your table?
> Best regards,
> Bart
>> Hi all,
>> I have made some spatial queries (with cgi-bin Mapserver 4.2.3)
>> alternately with data stored in shapefiles and PostGIS (imported from
>> these shapefiles).
>> My query (304 elements on 5 layers) takes 5 seconds (elaboration, and
>> then output on browser) if data are read from shapefiles, and about 50
>> seconds if data are read from PostGIS.
>> The query is the same: I simply press "reload" on my browser (after
>> manually changed .map file and query template files) to be sure of
>> it...
>> Is it normal?
>> Daniele
>> P.S.:
>> My system is a Linux Red Hat 9.
>> My mapserver is:
>> $ ./mapserv -v
>> MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> Postgresql and PostGIS are installed from RPMs (the version is:
>> postgresql-postgis-7.3.4-3.rri1.i386.rpm).
