Layers do not show up?
w m
wokar1 at YAHOO.COM
Thu Feb 10 15:44:37 EST 2005
I was making a simple map file. I'm able to display the map, but when i add the "landcover" layers, they don't show up on the map. I'm not sure why it doesn't show up???
Also, does it matter if I include the fontset? what is it used for?
WHat is the purpose of IMAGEPATH and IMAGEURL? If I don't include these it doesn't make a difference. Why is that?
The legend doesn't show up either.
It can be viewed here: http://132.205.108.60
I put all my files in the cgi-bin along with mapserver.
NAME europe
STATUS ON
IMAGETYPE PNG
IMAGECOLOR 255 255 255 # white background
EXTENT 407.997812 4103475.750 443135.000 4157027.250
#FONTSET "/usr/local/etc/htdocs/mapserver/fonts/fonts.list"
SIZE 500 500
SHAPEPATH "/var/www/cgi-bin"
# Set your template file to the name of YOUR template file
# you can leave the image path and image URL alone
WEB
TEMPLATE "/var/www/html/index.html"
IMAGEPATH "/usr/local/etc/htdocs/tmp/"
IMAGEURL "/tmp/"
END
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 10
ANTIALIAS TRUE
END
END
# LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME "myoutline"
DATA europa
STATUS DEFAULT # Show the layer at all times
TYPE LINE
CLASS
COLOR 0 0 0
OUTLINECOLOR 255 120 60
END
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
50 480 # changes the location of the text
END
TEXT 'Europe Map'
END
CLASS
LABEL
TYPE BITMAP
POSITION CR
COLOR 255 120 60
END
END
END
LAYER #
NAME "mylandcover"
DATA nhtm93s3
STATUS ON # show layer, but allow it to be turned off
TYPE POLYGON # choices for type are POLYGON, LINE and POINT
CLASSITEM "LANDCOVER"
CLASS # water
NAME "Water"
EXPRESSION 'Water' # match only those where [landcover]='Water'
COLOR 225 225 255
OUTLINECOLOR 0 0 0
END
CLASS # grassland
NAME "Grassland"
EXPRESSION /Planted*/ # search for landcovers starting with Planted
COLOR 0 240 0
OUTLINECOLOR 0 0 0
END
CLASS # forest
NAME "Forest"
EXPRESSION /Forest*/
COLOR 200 140 0
OUTLINECOLOR 0 0 0
END
CLASS # salt marsh
NAME "Salt Marsh"
EXPRESSION /Salt*/
COLOR 0 200 140
OUTLINECOLOR 0 0 0
END
CLASS # sand
NAME "Sand"
EXPRESSION /Bare*/
COLOR 240 240 240
OUTLINECOLOR 0 0 0
END
END # end of layer object
LAYER
NAME "myroads"
DATA rtf100k
STATUS ON
TYPE line
CLASS
NAME Roads
COLOR 200 0 200
OUTLINECOLOR 0 0 0
END # end of class
END # end of map file
Do you Yahoo!?
Yahoo! Mail - You care about security. So do we.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050210/ad579a36/attachment.html
