Layers do not show up?
Jeff Portwine jdport at VERITIME.COM
Thu Feb 10 16:25:22 EST 2005
It's not generally a good idea to put all of your files in the cgi-bin directory.   You should only have the mapserv directory there, and your other files in your normal html directory like /var/www/<directory>   or something like that.    The Imagepath is the complete path to the temp directory where your map images will be stored... the ImageURL would be the URL to the images.   For example you might have something like
Imagepath  /var/www/map/tmp
ImageURL /map/tmp.
The fontset is only used for labels if you have any text labels on your map.
Your legend likely doesn't show up because you haven't named any of your classes.   Only named classes will show up on a legend.
-Jeff
  ----- Original Message -----
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Sent: Thursday, February 10, 2005 3:44 PM
  Subject: [UMN_MAPSERVER-USERS] Layers do not show up?
  I was making a simple map file.  I'm able to display the map, but when i add the "landcover" layers, they don't show up on the map. I'm not sure why it doesn't show up???
  Also, does it matter if I include the fontset? what is it used for?
  WHat is the purpose of IMAGEPATH and IMAGEURL? If I don't include these it doesn't make a difference. Why is that?
  The legend doesn't show up either.
   It can be viewed here: http://132.205.108.60
  I put all my files in the cgi-bin along with mapserver.
  NAME europe
  STATUS ON
  IMAGETYPE PNG
  IMAGECOLOR 255 255 255 # white background
  EXTENT 407.997812 4103475.750 443135.000 4157027.250
  #FONTSET "/usr/local/etc/htdocs/mapserver/fonts/fonts.list"
  SIZE 500 500
  SHAPEPATH "/var/www/cgi-bin"
  # Set your template file to the name of YOUR template file
  # you can leave the image path and image URL alone
  WEB
  TEMPLATE "/var/www/html/index.html"
  IMAGEPATH "/usr/local/etc/htdocs/tmp/"
  IMAGEURL "/tmp/"
  END
  LEGEND
            STATUS ON
          LABEL
  TYPE TRUETYPE
  FONT arial
  COLOR 0 0 0
  SIZE 10
  ANTIALIAS TRUE
  END
  END
  # LAYER DEFINITIONS ---------------------------------------------
  LAYER
  NAME "myoutline"
  DATA europa
  STATUS DEFAULT # Show the layer at all times
  TYPE LINE
  CLASS
  COLOR 0 0 0
  OUTLINECOLOR 255 120 60
  END
  END
  LAYER
  NAME "credits"
  STATUS DEFAULT
  TRANSFORM FALSE
  TYPE ANNOTATION
  FEATURE
  POINTS
  50 480 # changes the location of the text
  END
  TEXT 'Europe Map'
  END
  CLASS
  LABEL
  TYPE BITMAP
  POSITION CR
  COLOR 255 120 60
  END
  END
  END
  LAYER #
  NAME "mylandcover"
  DATA nhtm93s3
  STATUS ON # show layer, but allow it to be turned off
  TYPE POLYGON # choices for type are POLYGON, LINE and POINT
  CLASSITEM "LANDCOVER"
  CLASS # water
  NAME "Water"
  EXPRESSION 'Water' # match only those where [landcover]='Water'
  COLOR 225 225 255
  OUTLINECOLOR 0 0 0
  END
  CLASS # grassland
  NAME "Grassland"
  EXPRESSION /Planted*/ # search for landcovers starting with Planted
  COLOR 0 240 0
  OUTLINECOLOR 0 0 0
  END
  CLASS # forest
  NAME "Forest"
  EXPRESSION /Forest*/
  COLOR 200 140 0
  OUTLINECOLOR 0 0 0
  END
  CLASS # salt marsh
  NAME "Salt Marsh"
  EXPRESSION /Salt*/
  COLOR 0 200 140
  OUTLINECOLOR 0 0 0
  END
  CLASS # sand
  NAME "Sand"
  EXPRESSION /Bare*/
  COLOR 240 240 240
  OUTLINECOLOR 0 0 0
  END
  END # end of layer object
  LAYER
  NAME "myroads"
  DATA rtf100k
  STATUS ON
  TYPE line
  CLASS
  NAME Roads
  COLOR 200 0 200
  OUTLINECOLOR 0 0 0
  END # end of class
  END # end of map file
  Do you Yahoo!?
  Yahoo! Mail - You care about security. So do we.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050210/8333fd8b/attachment.html
