extent is invalid for geotiff
John Bonk
bonk at EOSDATA.GSFC.NASA.GOV
Thu Feb 10 15:54:39 EST 2005
Ed,
Thank you again for responding to my question.
I'm still having problems understanding extent.
When I serve up my geotiff with your extent using
MAP
IMAGETYPE PNG
EXTENT -13053641.3 3358256.867 -932579.471 5752577.812
SIZE 400 300
SHAPEPATH "data"
LAYER # MODIS raster layer begins here
NAME modis
DATA RGB_mosaic_250m.tif
STATUS DEFAULT
TYPE RASTER
END # MODIS raster layer ends here
END # end of map file
I end up with an image that is smaller than I would expect, and offset
vertically.
If I add an html template to the above and serve the geotiff in the browse
mode, the image in the geotiff occupies a very small area in the png that
is produced. The geotiff image is left justified and centered vertically
in the png.
Can anyone explain why this is? How can I get the geotiff image to fill
the entire png?
John
At 09:41 2005-02-08 -0500, Ed McNierney wrote:
>John -
>No, there isn't any preferred method. A GeoTIFF will hold projection,
>datum, and bounding box information in a way that can be read by
>MapServer. As long as the GeoTIFF is created properly (i.e. you can't
>leave out the projection) the coordinate formats used don't matter.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of John Bonk
>Sent: Monday, February 07, 2005 11:39 AM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] extent is invalid for geotiff
>Ed,
>Thank you, that worked. I seems obvious now when I look back at the
>documentation.
>Perhaps someone can answer another question. In creating geotiffs, is
>there a preferred way of specify coordinates (degrees, UTM, etc) so
>that the image will work well with MapServer?
>Thanks again for the response,
>John
>At 23:10 2005-02-04 -0500, Ed McNierney wrote:
> >John -
> >If that's the only data layer in your map, ignore PROJECTION
> >completely, at least for now.
> >Have you tried an EXTENT of:
> > - Ed
> >Ed McNierney
> >TopoZone.com
> >On Behalf Of John Bonk
> >Sent: Friday, February 04, 2005 5:08 PM
> >Subject: [UMN_MAPSERVER-USERS] extent is invalid for geotiff
> >I am very new at this. I am having problems serving a geotiff image
> >with the following attributes:
> >Projection Method: CT_Equirectangular
> > ProjCenterLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
> > ProjCenterLongGeoKey: 0.000000 ( 0d 0' 0.00"E)
> > ProjFalseEastingGeoKey: 0.000000 m
> > ProjFalseNorthingGeoKey: 0.000000 m
> >Corner Coordinates:
> >Upper Left (-13053641.300,5752577.812)
> >Lower Left (-13053641.300,3358256.867)
> >Upper Right (-9325729.471,5752577.812)
> >Lower Right (-9325729.471,3358256.867)
> >Center (-11189685.386,4555417.340)
> >I have tried all sorts of variation of these number in the EXTENT field
> >but I have been getting an 'extent is invalid' message.
> >Can anyone help me express the EXTENT and PROJECTION to read this file?
> >John
John Bonk
SSAI/NASA GES DISC
Phone:(301) 614-5280
Fax: (301) 614-5268
For more information about
the NASA GES DISC and its services:
http://daac.gsfc.nasa.gov/
