Install Problem - error loading libgd
Attila Csipa
plists at PROMETHEUS.ORG.YU
Thu Feb 10 18:57:00 EST 2005
On Friday 11 February 2005 00:03, Jeff Berry wrote:
> /mapserv: error while loading shared libraries: libgd.so.2: cannot open
> shared object file: No such file or directory
> I do indeed have libgd.so.2 installed in /usr/local/lib. The
> configuration setup I used for mapserver is:
> Any ideas why mapserver cant see the library? Im at a loss.
Is /usr/local/lib in in your ldpath (see /etc/ld.so.conf) ? You might also
want to check "ldconfig -p|grep libgd".
