mapserv segfaults
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Thu Feb 10 19:54:49 EST 2005
Hi John,
Sorry to come in late in the game... ;) Frank might have just scored the
final point.
This issue with TIFF (and JPEG) has been around for awhile and comes up now
and then. In general when compiling MapServer with GDAL support, the
MapServer TIFF (and JPEG) support should be disabled. Anyway, if you follow
Frank's advice you should be able to compile your SDE support back.
Good luck!
-Perry
On Thursday 10 February 2005 03:01 pm, Frank Warmerdam wrote:
> On Thu, 10 Feb 2005 13:57:58 -0700, John C Cartwright
> <John.C.Cartwright at noaa.gov> wrote:
> > Any ideas on what I should try next? I specified
> > --with-libtiff=internal --with-geotiff=internal in the GDAL config. If
> > I specify a --with-tiff=DIR in the mapserver config, is that library
> > used or the one in the GDAL config?
> John,
> Generally speaking if you are using GDAL there is no reason to use
> the --with-tiff option for MapServer. The built-in use of libtiff is not
> nearly as flexible as using it through GDAL.
> If you build MapServer --without-tiff and if nothing else drags in
> libtiff other than GDAL then you should be ok. If something else
> is dragging in libtiff, then ensure you build GDAL to use the same
> libtiff rather than it's internal copy.
> The key is to configure things to ensure there is only one libtiff
> or your life can be hell.
> Best regards,
>--- I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com light and sound - activate the windows |
> http://pobox.com/~warmerdam and watch the world go round - Rush |
> Geospatial Programmer for Rent
Dept. of Ecology, Evolution, and Behavior
University of Minnesota
work: 612 624 6713
e-mail: nacional at cbs.umn.edu
