queryBypoint problem - Please help
Ruggero Valentinotti
valruggero at LIBERO.IT
Sun Feb 13 03:54:31 EST 2005
Nagu Govind wrote:
> Hi,
> Iam using MapScript.
> I want to find out the State and District name using latiudes and
> longitudes. My .dbf file has the following fields
> 1.Dst_ID
> 2.District
> 3. State
> I want to get this info corresponding to my lat and long.
> My map file layer is like this
> MAP
> NAME "ind"
> SIZE 500 500
> STATUS ON
> SYMBOLSET "maps/symbols/examples.sym"
> EXTENT 67 5 99 40
> SHAPEPATH "maps/data/"
> PROJECTION
> "proj=latlong"
> "datum=NAD83"
> END
> WEB
> IMAGEPATH "maps/tmp/"
> IMAGEURL "maps/ <http://nagaraj:9000/maps/tmp/>"
> TEMPLATE 'maps/myind.html'
> END
> QUERYMAP
> STATUS ON
> STYLE SELECTED
> COLOR 255 255 0
> END
> LAYER
> NAME "Ind"
> TYPE POLYGON
> STATUS ON
> DATA "ind_ds"
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> END
> CLASS
> NAME "IND MAP"
> OUTLINECOLOR 0 0 0
> COLOR 255 255 0
> SYMBOL dash-long
> STATUS ON
> END
> TEMPLATE ind_query.html
> END
> END
> And Iam calling Query by point as folows
> $point = ms_newpointObj();
> $point->setXY($lon,$lat);
> $layer1 = $map->getLayerByName('Ind');
> if($layer1->queryBypoint($point,MS_SINGLE,$buffer) == MS_SUCCESS){
> echo "Success : $buffer";
> Iam getting this warning message
> Warning: [MapServer Error]: msQueryByPoint(): No matching record(s)
> found.
> Iam new to mapserver & I really dont know whether this is the right
> method to get the info from the dbf file. Iam having only one polygon
> layer. Do i need to have another layer for quering.?.
> Please tell me where Iam going wrong.
> The concepts of layers are also not much clear to me. Regarding
> Mapscript and Map File , reference documents are there but I could not
> find any elaborate examples or application notes.
> Please tell me where i can find them.
> I also could not find any good samples similar to my requirement.
> Some one please help me.
> Regards
> vdharan
> Do you Yahoo!?
> Yahoo! Mail
> <http://us.rd.yahoo.com/mail_us/taglines/virus/*http://promotions.yahoo.com/new_mail/static/protection.html>
> - Helps protect you from nasty viruses.
Hi Nagu,
you need METADATA keyword in Layer class:
LAYER
NAME "Ind"
TYPE POLYGON
STATUS ON
METADATA
"DESCRIPTION" "My layer ind"
"RESULT_FIELDS" "DISTRICT STATE"
END
DATA "ind_ds"
PROJECTION
"proj=latlong"
"ellps=GRS80"
END
CLASS
NAME "IND MAP"
OUTLINECOLOR 0 0 0
COLOR 255 255 0
SYMBOL dash-long
STATUS ON
END
END
And then use Use '@' to avoid warning if query found nothing
@$layer1->queryBypoint($point,MS_SINGLE,$buffer);
Hope this help
ruggero
/\ Ruggero Valentinotti
//\\ /\ Studio Tecnico Ambientale Forestale
///\\\//\\ Frazione Tozzaga - Via alle Pozze, 2
////\\\\/\\\ 38022 CALDES (TN) - Italy
||////\\\\\ http://digilander.libero.it/valruggero/
_____||___||_____ E-mail: valruggero at libero.it
