queryBypoint problem - Please help
Nagu Govind
lsnagu at YAHOO.COM
Sun Feb 13 04:23:57 EST 2005
Hi Ruggero,
Thanks for your reply.
I added the MetaData Key word in layer as follows.
METADATA
"DESCRIPTION" "My layer ind"
"RESULT_FIELDS" "DISTRICT STATE"
END
But I still get the same warning "Warning: [MapServer
Error]: msQueryByPoint(): No matching record(s)
found".
I change the Lat and Lon and checked but there is no
change.
Please tell me Where Iam going wrong?. Is there any
thing else i have to check.
Regards
Nagu
--- Ruggero Valentinotti <valruggero at libero.it> wrote:
> Nagu Govind wrote:
> > Hi,
> > Iam using MapScript.
> > I want to find out the State and District name
> using latiudes and
> > longitudes. My .dbf file has the following fields
> > 1.Dst_ID
> > 2.District
> > 3. State
> > I want to get this info corresponding to my lat
> and long.
> > My map file layer is like this
> > MAP
> > NAME "ind"
> > SIZE 500 500
> > STATUS ON
> > SYMBOLSET "maps/symbols/examples.sym"
> > EXTENT 67 5 99 40
> > SHAPEPATH "maps/data/"
> > PROJECTION
> > "proj=latlong"
> > "datum=NAD83"
> > END
> > WEB
> > IMAGEPATH "maps/tmp/"
> > IMAGEURL "maps/ <http://nagaraj:9000/maps/tmp/>"
> > TEMPLATE 'maps/myind.html'
> > END
> > QUERYMAP
> > STATUS ON
> > STYLE SELECTED
> > COLOR 255 255 0
> > END
> > LAYER
> > NAME "Ind"
> > TYPE POLYGON
> > STATUS ON
> > DATA "ind_ds"
> > PROJECTION
> > "proj=latlong"
> > "ellps=GRS80"
> > END
> > CLASS
> > NAME "IND MAP"
> > OUTLINECOLOR 0 0 0
> > COLOR 255 255 0
> > SYMBOL dash-long
> > STATUS ON
> > END
> > TEMPLATE ind_query.html
> > END
> > END
> > And Iam calling Query by point as folows
> > $point = ms_newpointObj();
> > $point->setXY($lon,$lat);
> > $layer1 = $map->getLayerByName('Ind');
> > if($layer1->queryBypoint($point,MS_SINGLE,$buffer)
> == MS_SUCCESS){
> > echo "Success : $buffer";
> > Iam getting this warning message
> > Warning: [MapServer Error]: msQueryByPoint(): No
> matching record(s)
> > found.
> > Iam new to mapserver & I really dont know whether
> this is the right
> > method to get the info from the dbf file. Iam
> having only one polygon
> > layer. Do i need to have another layer for
> quering.?.
> > Please tell me where Iam going wrong.
> > The concepts of layers are also not much clear to
> me. Regarding
> > Mapscript and Map File , reference documents are
> there but I could not
> > find any elaborate examples or application notes.
> > Please tell me where i can find them.
> > I also could not find any good samples similar to
> my requirement.
> > Some one please help me.
> > Regards
> > vdharan
> > Do you Yahoo!?
> > Yahoo! Mail
<http://us.rd.yahoo.com/mail_us/taglines/virus/*http://promotions.yahoo.com/new_mail/static/protection.html>
> > - Helps protect you from nasty viruses.
> Hi Nagu,
> you need METADATA keyword in Layer class:
> LAYER
> NAME "Ind"
> TYPE POLYGON
> STATUS ON
> METADATA
> END
> DATA "ind_ds"
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> END
> CLASS
> NAME "IND MAP"
> OUTLINECOLOR 0 0 0
> COLOR 255 255 0
> SYMBOL dash-long
> STATUS ON
> END
> END
> And then use Use '@' to avoid warning if query found
> nothing
> @$layer1->queryBypoint($point,MS_SINGLE,$buffer);
> Hope this help
> ruggero
> /\ Ruggero Valentinotti
> //\\ /\ Studio Tecnico Ambientale
> Forestale
> ///\\\//\\ Frazione Tozzaga - Via alle
> Pozze, 2
> ////\\\\/\\\ 38022 CALDES (TN) - Italy
> http://digilander.libero.it/valruggero/
> _____||___||_____ E-mail: valruggero at libero.it
__________________________________
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
