mapserver with java support
Umberto Nicoletti
unicoletti at PROMETEO.IT
Mon Feb 14 08:56:03 EST 2005
The basic steps to get java mapscript going are:
1) compile mapserver. the following options are strongly suggested:
--use-threads --use-proj
2) cd to mapscript/java
3) read README
4) optionally run make interface (in your case you shouldn't)
4) run make
5) run the examples: make test
HTH,
Umberto
On Mon, 2005-02-14 at 15:41 +0200, temiz wrote:
> hello
> is this correct to compile mapserver with java support ?
> --with-java=/usr/local/j2sdk1.4.2_07/ \
> I am confused on mapserver - java installation in wiki's page
> is there any page or which shows steps to build an application for java?
> regards
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Umberto Nicoletti <unicoletti at prometeo.it>
Prometeo SRL
